13-04-2025, 02:11:34
Pagina's: 1 ... 89 90 91 92 [93] 94 95 96 97 ... 123 Omlaag Print
Auteur Topic: Volvo oceanrace 2014 / 2015  (gelezen 1338629 keer)
« Antwoord #1380 Gepost op: 22-04-2015, 10:04:08 »
0700 gmt.
nou ze zijn er al weer afgegooid,zal wel met friendjes politiek te maken hebben.
« Laatste verandering: 04-05-2015, 00:06:11 door zier » Gelogd
« Antwoord #1381 Gepost op: 22-04-2015, 10:48:03 »
One team that may need to find a little more patience than most is Dongfeng Race Team. They have undergone a repair to their broken water-maker by wrapping the split tube with carbon in an attempt to seal the crack.
The glue used is curing now so it will still be a few hours before the crew dares to test the fix. This will be a tense moment as they probably only have one attempt at this. If it works then happy days, if not they have two very unsatisfactory options.
Option one is to make a pit stop in a port of their choice and pick up a new part. If they do this, the rules say they must stop for a minimum of 12 hours. Recent leg finish history would say they they would probably not catch up so potentially they would be signing up to a sixth place.
Option two is for those thirsty crew to carry on using their emergency water-maker, and manually and painfully pump their way out of trouble. Extreme races sometimes need extreme choices. Let’s hope that the repair works!
« Antwoord #1382 Gepost op: 22-04-2015, 12:54:54 »
1000 gmt.
« Laatste verandering: 04-05-2015, 00:06:19 door zier » Gelogd
« Antwoord #1383 Gepost op: 22-04-2015, 15:54:50 »
SCA
At the moment it’s all about performance and numbers, making sure we are operating at 100% and in the correct mode for optimal boat speed. After all, the most important thing for us at the moment is to maintain our current foothold in the fleet.
DE meiden zijn zo trots als een hond met 7 l.ll.n dat ze continue in de kopgroep zitten.  Grin Grin Grin
« Antwoord #1384 Gepost op: 22-04-2015, 17:03:17 »
Dongfeng 17.00 uur
The water maker seems to have been fixed and hasn’t exploded after it’s second use.
Zo te lezen hebben ze geluk
« Antwoord #1385 Gepost op: 23-04-2015, 00:11:47 »
https://www.youtube.com/watch?v=Nj9MTQAFg1c
https://www.youtube.com/watch?v=bPDONZHzrzM
« Antwoord #1386 Gepost op: 23-04-2015, 00:23:22 »
2200
geen verrassingen
« Laatste verandering: 11-05-2015, 12:53:07 door jacobcramer » Gelogd
« Antwoord #1387 Gepost op: 23-04-2015, 10:00:16 »
0700 gmt.
der zijn er die al een beetje zenuwachtig worden ,met de aanstaande wind veranderingen.
« Laatste verandering: 04-05-2015, 00:06:31 door zier » Gelogd
« Antwoord #1388 Gepost op: 23-04-2015, 12:29:32 »
1000 gmt.
of dat nou zo wijs was die korte slag naar de west,of was het een valse schijn beweging,om te kijken of ieder een nog bij de les is.
want je kan maar beter zo oostelijk mogenlijk zitten kan je straks de wind iets ruimer zeilen
« Laatste verandering: 04-05-2015, 00:06:39 door zier » Gelogd
« Antwoord #1389 Gepost op: 23-04-2015, 14:43:41 »
SCA 11.15 uur
De meiden hebben wat problemen met een liertrommel.
Team SCA reported that their port runner winch drum had cracked while under load. Abby Ehler confirmed, that the team had swapped out the pit runner winch drum and were trying to fix the port runner winch to make it usable as a pit winch
« Antwoord #1390 Gepost op: 23-04-2015, 18:47:27 »
1600 gmt.
nou ze hebben nog mooi de tijd om hem te maken.
hebben ze marzel dat ze die korte slag naar de west gemaakt hebben ,anders hadden ze voor een verassing komen te staan.
« Laatste verandering: 04-05-2015, 00:06:47 door zier » Gelogd
« Antwoord #1391 Gepost op: 23-04-2015, 21:16:00 »
Dongfeng
Watermaker gefixt
https://www.youtube.com/watch?v=C0QIkOzz1aE
SCA
Liertrommel is vervangen. Er was een reserve aan boord
Dagrapport 23-04-2015
https://www.youtube.com/watch?v=HpxML2O9dSU&feature=youtu.be
« Laatste verandering: 23-04-2015, 21:23:25 door Knorhaan » Gelogd
« Antwoord #1392 Gepost op: 23-04-2015, 21:53:48 »
De verschillen zijn zo klein dat ze de mijlen opgeven tot 2 cijfers achter de komma en de snelheid tot 1 cijfer achter de komma.
« Laatste verandering: 04-05-2015, 00:11:58 door Knorhaan » Gelogd
« Antwoord #1393 Gepost op: 23-04-2015, 23:38:53 »
http://www.volvooceanracefestivaldenhaag.com/
« Antwoord #1394 Gepost op: 24-04-2015, 01:06:04 »
2200
die gasten slopen alles aan boord  Boos
dat had nog niet gelezen Karel maar alles is al geregeld ,ik had er ook nog nix op FB
over gelezen , als ze lezen dat het programma later klaar is dan de laatste bus en tram Huh
« Laatste verandering: 11-05-2015, 12:53:22 door jacobcramer » Gelogd
Pagina's: 1 ... 89 90 91 92 [93] 94 95 96 97 ... 123 Omhoog Print
